RaceCapture-Apex
(Redirected from RaceCapture Apex)
Product Brief
By Car
By Sensor Type
Reference
STL file for replacement access door
Use this STL file to create a replacement for the access port. Use a flexible resin or filament for proper operation.
File:Rc apex door.stl.zip
Quick Start
Powering Up
Powering via 12v
Connect 12-24v and Ground to the connections on the connector according to the pinout in the [[RacecaptureApex_hardware_install]|ardware installation guide]].
Testing on the Bench
Launch the app
Bluetooth (Android Only)
WiFi (iOS or Android)
Windows Requirements
USB Drivers
  • Windows XP, 7 or 8
OSX
Connecting and running
RaceCapture App Tour
Navigating dashboard screens
Setup Mode
Explanation of buttons
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Navigating data
Selecting time vs distance
