PodiumConnect Micro
Quick Start Guide
Connecting the Hardware
Mounting
Pigtail Connection
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Create Your Podium Account
  • Create an account on Podium
  • Setup the Device Name
Windows/OSX
  • Get the latest version of the RaceCapture app from the DOWNLOADS PAGE.
  • Connect your Podium Connect Micro to your computer with the USB cable,
  • Start the RaceCapture app.
Android/iOS
First-Time Setup Wizard
Configure System Presets
Select Favorite Race Tracks
Verify Telemetry
Verifying Wi-Fi
  • Verify Client is connected
Verify Telemetry on Podium
Comprehensive Setup Guide
Data System Cable Connection
1 CAN low White
3 CAN high Green
4 Ground Black
AIM Standard Cable
CAN Bus Configuration
Baud Rate, Termination
CAN Channel Mapping Guide
640PX
Driver ID
Heart Rate Monitoring
Setup Instructions
  • Ensure your PodiumConnect/Micro system is upgraded to the latest firmware and the latest version of the RaceCapture app is installed.
To Verify:
Racecapture
Podium
Telemetry and Logging Setup
Enabling WiFi Telemetry
On Board Flash Memory Logging
To enable USB drive mode:
Important Caveats:
Formatting Flash Memory:
Real-Time Podium Features
Setting Up Podium App
  • Create an account on Podium.
  • Open the Settings section and Add the name for your device.
  • Once your device is created, a Streaming ID will be generated. Make a note of this ID, so you can enter it into the RaceCapture wizard later.
Live Data Streaming
Predictive Lap Timing
  • ● Podium Connect Micro offers a Predictive Lap Timing feature, which estimates your current lap time before it’s completed.
Driver Coaching Tools
Need more information
Monitoring Engine Vitals
Endurance Strategy Tools
Firmware and Software Updates
Backing Up Configurations
Updating Firmware
  • Press Open
Restoring Settings
LED and Status Indicators
  • Power Icon : Indicates system power is on.
  • Error Indicator – Triangle with Exclamation Mark : Signals an error, such as a Lua script failure or a local logging error.
  • Telemetry Indicator – Cloud with Arrow : Shows that telemetry is actively broadcasting.
  • CAN Bus Activity – Two Arrows (⇄) : Shows ongoing CAN bus communication, confirming data exchange with connected systems.
Technical Specifications
Analog Inputs
CAN Bus
CAN Channels 1
CAN Bus CAN 2.0 compatible
CAN Channels Supported 100
Telemetry Connection
WiFi Standard 802.11b/g/n
Storage
Onboard SD Minimum 2GB
Max Sample Rate to SD 100Hz
Sectors per Track 20
Export Data Format Plain CSV
Scripting / Customization
Physical
Temperature Range 0 to 65°C
Weight 100g (3.6 oz)
Power Consumption (Max) 0.6W
