RaceCapture-Pro MK2
Revision as of 16:41, 1 March 2017 by Brentp (talk | contribs)
RaceCapture/Pro Quick Links
Getting Started
User Guides
Accessory / add-on guides
By Car
By Sensor Type
Reference
More Information
Previous Hardware Versions
RaceCapture/Pro MK1
Quick Reference
Download a printable PDF
Input / Output Channels
Analog Inputs
Voltage range 0-5v
Input impedance 1M ohm
ADC precision 12 bit
Maximum sample rate 1000Hz
Digital I/O
Channels 3
Output mode type Open drain
Channels 3
PWM/Analog outputs
Channels 4
PWM output type push/pull
PWM output voltage range 5v
Output current capacity 50mA
Analog Output 0-5v
Voltage Reference
Connectivity
CAN Bus
CAN Channels 2
CAN filters 14 per channel
Telemetry/Wireless
Max Baud Rate 230400
Inertial Motion Unit
GPS Maximum sample rate 50Hz
GPS accuracy 2.5M CEP
Storage
Configuration Capacity
Sectors per track 20
Channel support 200
Physical
Weight 9oz / 255gm (est)
RJ45: 1A max
With Bluetooth: 1.6W
With Cellular Telemetry: 8.6W
