RaceCapture-Pro MK3
Product Brief
- Jump to quick start guide
- Hardware Installation guide
- Real-time Telemetry guide
- Logging Data
- CAN bus / ECU sensor guide
- Lua scripting guide
- Lua script examples
- Sensor guide
- Add TPMS data for $225
- How to: get best GPS data
- How to update firmware
- More FAQs and How-To's
- How To Videos
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Testing on the Bench
Launch the RaceCapture app
Bluetooth (Android Only)
WiFi (iOS or Android)
Raspberry Pi
Connect to your RaceCapture system (On your laptop / desktop)
You can also run the RaceCapture app on your desktop or laptop to make it easier to set up, change settings and view analysis data.
Windows Requirements
USB Drivers
- Windows XP, 7 or 8
OSX
Connecting and running
RaceCapture App Tour
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Selecting time vs distance
| Sensors | |
| Analog Inputs | |
| Channels | 9 (8 external + 1 internal battery/supply voltage) |
| Voltage range | 0-5v |
| Input impedance | Greater than 1M ohm |
| Voltage Protection | 400v (intermittent) |
| ADC precision | 12 bit |
| Mapping | Raw / linear formula / interpolated map |
| Digital I/O | |
| Channels | 3 |
| Output mode type | Open Drain |
| Input voltage protection | 0-40v |
| Timer inputs (RPM / Frequency) | |
| Channels | 4 |
| Mapping | RPM, Frequency |
| Voltage Reference | |
| Output Voltage / Capacity | 5v / 500mA |
| CAN Bus | |
| CAN Channels | 2 |
| Serial | |
| Aux Serial | RS232 |
| Max Baud Rate | 230400 |
| Maximum Sample Rate | 10Hz |
| Wireless | |
| WiFi | 802.11bgn |
| Bluetooth | Bluetooth 2.0 |
| Maximum Sample Rate | 50Hz (Bluetooth and WiFi) |
| GPS | |
| Sample Rates supported | 1 / 5 / 10 / 25 / 50Hz |
| GPS accuracy | 2.5M CEP |
| Inertial Motion Unit | |
| Gyro Channels | 3 (Yaw/Pitch/Roll) (1000 degrees/sec) |
| Storage | |
| CAN bus direct mapping | 30 direct CAN mapping channels |
| Capabilities | |
| Channel Support | 200 |
| Track maps | 200 built in for autonomous auto-detection; unlimited via RaceCapture app with interactive track map builder |
| Sectors per track | 20 |
| Analysis | Included in the RaceCapture App |
| Export data format | Plain CSV (RaceRender compatible) |
| Physical | |
| Dimensions | 150 x 85 x 30mm (5.9 x 3.35 x 1.18in) |
| Weight | 255g (12 oz) |
| Physical | Molex Connector, 24 pins SMA for external GPS antenna SMA for cellular module |
| Power Consumption (max) | Main System: 0.6W With Wireless: 1.6W With Cellular Telemetry: 8.6W With Cellular Telemetry and Wireless active: 9.6W |
