PodiumConnect Micro
Quick Start Guide
Connecting the Hardware
Mounting
Pigtail Connection
Male connector pictured
| Pin | Connection | Notes |
| 1 | CAN low | White |
| 3 | CAN high | Green |
| 4 | Ground | Black |
Create Your Podium Account
- Create an account on Podium
- Setup the Device Name
Downloading and Installing the Podium App
Windows
- Get the latest version of the Podium App from the DOWNLOADS PAGE.
- Download the .exe file for Windows.
- Run the setup wizard and follow the on-screen instructions to complete the installation.
- Once installed, launch the app and log in using your Podium account.
macOS
Android/iOS
- Get the latest version of the Podium app from the following.
Creating an Event and Adding Devices
- Create an Event
- In the app, go to My Events and click Create Event.
- Enter your Event Title, Start and End Dates, and Track details.
- Add Devices
- After creating an event, add one or more devices to it.
- This enables you to stream telemetry data and compare laps directly within the dashboard.
First-Time Setup Wizard
Configure System Presets
Select Favorite Race Tracks
Verify Telemetry
Verifying Wi-Fi
- Verify Client is connected
Verify Telemetry on Podium
Comprehensive Setup Guide
Data System Cable Connection
AIM Standard Cable
CAN Bus Configuration
Baud Rate, Termination
CAN Channel Mapping Guide
Driver ID
Heart Rate Monitoring
Setup Instructions
To Verify:
Racecapture
Podium
Telemetry and Logging Setup
Enabling WiFi Telemetry
On Board Flash Memory Logging
To enable USB drive mode:
Important Caveats:
Formatting Flash Memory:
Real-Time Podium Features
Setting Up Podium App
- Create an account on Podium.
- Open the Settings section and Add the name for your device.
- Once your device is created, a Streaming ID will be generated. Make a note of this ID, so you can enter it into the RaceCapture wizard later.
Windows/OSX
- Get the latest version of the Podium app from the DOWNLOADS PAGE.
- Once installed, Connect your Podium Connect Micro to your computer with the USB cable,
- Start the RaceCapture app.
Android/iOS
Live Data Streaming
Predictive Lap Timing
Driver Coaching Tools
Need more information
Monitoring Engine Vitals
Endurance Strategy Tools
Firmware and Software Updates
Backing Up Configurations
Updating Firmware
- Press Open
Restoring Settings
LED and Status Indicators
Technical Specifications
| Analog Inputs | |
| CAN Bus | |
| CAN Channels | 1 |
| Telemetry Connection | |
| Wireless | |
| Storage | |
| Onboard SD | Minimum 2GB |
| Sectors per Track | 20 |
| Physical | |
| Weight | 100g (3.6 oz) |
- Logging Data
- Real-time Telemetry guide
- Lua scripting guide
- Lua script examples
- GoPro control guide
- Add TPMS data for $225
- How to update firmware
- More FAQs and How-To's
- How To Videos
