PodiumConnect Micro
Quick Start Guide
Connecting the Hardware
Mounting
Pigtail Connection
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Create Your Podium Account
  • Create an account on Podium
  • Setup the Device Name
Downloading and Installing the Podium App
Windows
  • Get the latest version of the Podium App from the DOWNLOADS PAGE.
  • Download the .exe file for Windows.
  • Run the setup wizard and follow the on-screen instructions to complete the installation.
  • Once installed, launch the app and log in using your Podium account.
macOS
Android/iOS
  • Get the latest version of the Podium app from the following.
Creating an Event and Adding Devices
  • Create an Event
    • In the app, go to My Events and click Create Event.
    • Enter your Event Title, Start and End Dates, and Track details.
  • Add Devices
    • After creating an event, add one or more devices to it.
    • This enables you to stream telemetry data and compare laps directly within the dashboard.
First-Time Setup Wizard
Configure System Presets
Select Favorite Race Tracks
Verify Telemetry
Verifying Wi-Fi
  • Verify Client is connected
Verify Telemetry on Podium
Wi-Fi Operating Modes
PodiumConnect Micro support multiple Wi-Fi operating modes to accommodate different configuration, connectivity, and telemetry use cases. Firmware version 2.23.3 introduces significant improvements to Wi-Fi reliability and connection behavior across all supported modes.
Access Point (AP) Mode
When operating in this mode:
Wi-Fi Reliability Improvements in Firmware v2.23.3
Firmware version 2.23.3 introduces multiple improvements to Wi-Fi reliability and connection stability for PodiumConnect/Micro. These updates are focused on improving real-world Wi-Fi behavior during configuration and telemetry use.
Summary of Improvements
  • Improved Wi-Fi connection stability during normal operation
  • More reliable reconnection behavior after temporary signal loss
  • Improved handling of access point and network transitions
  • Reduced likelihood of stalled or unresponsive Wi-Fi connections
  • Improved behavior during STA hotspot scanning
  • General robustness improvements when operating in environments with variable or congested wireless conditions
Real-time Telemetry Setup
This section explains how to configure PodiumConnect Micro to stream live telemetry data to the Podium cloud service so it can be viewed remotely using the Podium app or the Podium website.
Step 1 : Configure WiFi Connectivity
  • Select the Wireless tab.
      • Enable WiFi Support
      • Enable Client Mode
Step 2 : Configure the Telemetry Streaming Key
  • Open the Podium website.
Step 3 : Configure Streaming Behavior
Step 4: Apply Configuration and Reboot
Reboot the device by either:
  • Power cycling the unit, or
Step 5 : Verify WiFi Connection
After rebooting:
Step 6 : Confirm Telemetry Streaming
  • The telemetry LED on the device will blink, indicating the system is transmitting telemetry to Podium.
Viewing Live Telemetry
Podium Website
  • Navigate to Events.
    • IMU motion
    • G-forces
    • Sensor values
Podium App
  1. Open the Podium app.
  3. Select your device.
From here you can:
  • View live dashboards
  • Switch dashboard views
Dashboards can be:
  • Custom created and saved
  • Shared by the community
Track Detection and Lap Timing
  1. Navigate to Racetracks.
  • Lap timing
Comprehensive Setup Guide
Data System Cable Connection
1 CAN low White
3 CAN high Green
4 Ground Black
AIM Standard Cable
CAN Bus Configuration
Baud Rate, Termination
CAN Channel Mapping Guide
640PX
Driver ID
Heart Rate Monitoring
Setup Instructions
  • Ensure your PodiumConnect/Micro system is upgraded to the latest firmware and the latest version of the RaceCapture app is installed.
To Verify:
Racecapture
Podium
Telemetry and Logging Setup
Enabling WiFi Telemetry
On Board Flash Memory Logging
To enable USB drive mode:
Important Caveats:
Formatting Flash Memory:
Bluetooth Connectivity
PodiumConnect Micro support Bluetooth connectivity for communication with the RaceCapture app. Bluetooth can be used as an alternative to Wi-Fi for device setup, configuration, and telemetry access.
Default Bluetooth Password
Connecting via Bluetooth
  • Power on the PodiumConnect Micro
  • Once the PodiumConnect Micro is found, select it to pair.
Changing Connection Type
  • Open the RaceCapture app.
System Overview
Supported Features
  • PodiumConnect Micro support upto 16 TPMS sensors
    • Left Front
    • Right Front
    • Left Rear
    • Right Rear
Registering TPMS Sensors
  2. Select TPMS
  3. Select Register Sensor.
Sensor Identification Notes
Real-Time Podium Features
Setting Up Podium App
  • Create an account on Podium.
  • Open the Settings section and Add the name for your device.
  • Once your device is created, a Streaming ID will be generated. Make a note of this ID, so you can enter it into the RaceCapture wizard later.
Windows/OSX
  • Once installed, Connect your Podium Connect Micro to your computer with the USB cable,
  • Start the RaceCapture app.
Android/iOS
Live Data Streaming
Predictive Lap Timing
  • ● Podium Connect Micro offers a Predictive Lap Timing feature, which estimates your current lap time before it’s completed.
Driver Coaching Tools
Need more information
Monitoring Engine Vitals
Endurance Strategy Tools
Firmware and Software Updates
Backing Up Configurations
Updating Firmware
  • Press Open
Restoring Settings
LED and Status Indicators
  • Power Icon : Indicates system power is on.
  • Error Indicator – Triangle with Exclamation Mark : Signals an error, such as a Lua script failure or a local logging error.
  • Telemetry Indicator – Cloud with Arrow : Shows that telemetry is actively broadcasting.
  • CAN Bus Activity – Two Arrows (⇄) : Shows ongoing CAN bus communication, confirming data exchange with connected systems.
Technical Specifications
Analog Inputs
CAN Bus
CAN Channels 1
CAN Bus CAN 2.0 compatible
CAN Channels Supported 100
Telemetry Connection
WiFi Standard 802.11b/g/n
Storage
Onboard SD Minimum 2GB
Max Sample Rate to SD 100Hz
Sectors per Track 20
Export Data Format Plain CSV
Scripting / Customization
Physical
Temperature Range 0 to 65°C
Weight 100g (3.6 oz)
Power Consumption (Max) 0.6W
