RaceCapture-Pro MK2
RaceCapture/Pro Quick Links
Getting Started
User Guides
- CAN bus / ECU integration guide
- Hardware installation and operation guide
- 3.5G Module Upgrade guide
- RaceCapture App User's guide
- Sensor guide
- Lua scripting guide
Accessory / add-on guides
- WiFi module for automatic GoPro control guide
- How to: get best GPS data
- How to: analyze your data
- More FAQs and How-To's
By Car
By Sensor Type
Reference
More Information
Previous Hardware Versions
Quick Reference
Download a printable PDF
Input / Output Channels | |
Analog Inputs | |
Channels | 8 (battery voltage dedicated on channel 8) |
Voltage range | 0-5v |
Input impedance | 1M ohm |
Voltage protection | 400v (intermittent) |
ADC precision | 12 bit |
Maximum sample rate | 1000Hz |
Mapping | Raw / Linear formula / Interpolated map |
Digital I/O | |
Channels | 3 |
Output mode type | Open drain |
Output current capacity | 1A, inductive clamped |
Input voltage protection | 400v (intermittent) |
Timer Inputs (RPM / Frequency) | |
Channels | 3 |
PWM/Analog outputs | |
Channels | 4 |
PWM output type | push/pull |
PWM output voltage range | 5v |
Output current capacity | 50mA |
Analog Output | 0-5v |
Voltage Reference | |
Output Voltage/Capacity | 5v / 1A |
Connectivity | |
CAN Bus | |
CAN Channels | 2 |
CAN baud rate | 125K, 250K, 500K, 1M baud |
CAN Termination | 120 ohms terminated, both channels |
Protocol support | OBDII PID (CAN 1), custom CAN messaging |
Telemetry/Wireless | |
Cellular (North America) | 3.5G GSM 850/1900MHz (internal module, optional) |
Cellular (Worldwide) | 2.5G Quad-band GSM (internal module, optional) |
Bluetooth | Bluetooth 2.0 (external module, optional) |
Aux Serial | Type External RJ11 / RS232 signaling |
Max Baud Rate | 230400 |
Inertial Motion Unit | |
Accelerometer Channels | 3 (X/Y/Z) (2G, 4G capable) |
Gyro | 3 (Yaw/Pitch/Roll) (1000 degrees/sec) |
GPS Type | External active antenna |
GPS Maximum sample rate | 50Hz |
GPS accuracy | 2.5M CEP |
Storage | |
Micro SD | Up to 32GB (SDHC) FAT32 |
Configuration Capacity | |
Auto-detect track database | 240 |
Sectors per track | 20 |
Channel support | 200 |
Physical | |
Dimensions | 5.3" (width) x 4.2" (height) x 1.2" (tall) / 135x110x31 mm(est) |
Mounting area | 5.5"(140mm) x 4"(102mm) |
Mounting holes | Dual mounting points on 5" (127mm) centers - 0.125"-0.25" (3-6mm) fastener |
Weight | 9oz / 255gm (est) |
Power connection | Terminal block: 1A max RJ45: 1A max |
Power Consumption (max) | Main System: 0.6W With Bluetooth: 1.6W With Cellular Telemetry: 8.6W With Cellular Telemetry and Bluetooth: 9.6W |
Temperature | Max Internal Temperature while operating: -40°C ~ 85°C / -40°C ~ 80°C (Telemetry module) |
