RaceCapture-Pro MK3
Product Brief
- Jump to quick start guide
- Hardware Installation guide
- Real-time Telemetry guide
- Logging Data
- CAN bus / ECU sensor guide
- AIM Integration guide
- Lua scripting guide
- Lua script examples
- Sensor guide
- GoPro control guide
- Exporting to DashWare guide
- How to: get best GPS data
- How to update firmware
- More FAQs and How-To's
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Testing on the Bench
Launch the RaceCapture app
Bluetooth (Android Only)
WiFi (iOS or Android)
Windows Requirements
USB Drivers
- Windows XP, 7 or 8
OSX
Connecting and running
RaceCapture App Tour
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Selecting time vs distance
Applying Decals
