RaceCapture-Pro MK3
Product Brief
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Testing on the Bench
Launch the RaceCapture app
Bluetooth (Android Only)
WiFi (iOS or Android)
Raspberry Pi
You can run the RaceCapture App on a Raspberry pi for a more dedicated dashboard experience.
Connect to your RaceCapture system (On your laptop / desktop)
You can also run the RaceCapture app on your desktop or laptop to make it easier to set up, change settings and view analysis data.
Windows Requirements
USB Drivers
  • Windows XP, 7 or 8
OSX
Connecting and running
RaceCapture App Tour
Navigating dashboard screens
Setup Mode
Explanation of buttons
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Navigating data
Selecting time vs distance
Analog Inputs
Channels 9 (8 external + 1 internal battery/supply voltage)
Voltage range 0-5v
Input impedance Greater than 1M ohm
Voltage Protection 400v (intermittent)
ADC precision 12 bit
Maximum sample rate 1000Hz
Mapping Raw / linear formula / interpolated map
Digital I/O
Channels 3
Output mode type Open Drain
Input voltage protection 0-40v
Timer inputs (RPM / Frequency)
Channels 4
Mapping RPM, Frequency
Voltage Reference
Output Voltage / Capacity 5v / 500mA
CAN Bus
CAN Channels 2
CAN filters 14 per channel
Serial
Aux Serial RS232
Max Baud Rate 230400
Cellular Telemetry (Optional)
Cellular 3.5G GSM worldwide compatible
Maximum Sample Rate 10Hz
WiFi 802.11bgn
Bluetooth Bluetooth 2.0
Maximum Sample Rate 50Hz (Bluetooth and WiFi)
Sample Rates supported 1 / 5 / 10 / 25 / 50Hz
GPS accuracy 2.5M CEP
Inertial Motion Unit
Gyro Channels 3 (Yaw/Pitch/Roll) (1000 degrees/sec)
Storage
Micro SD Up to 32GB (SDHC)
CAN bus direct mapping 30 direct CAN mapping channels
Capabilities
Channel Support 200
Track Mapping Circut and point-point
Track maps 200 built in for autonomous auto-detection; unlimited via RaceCapture app with interactive track map builder
Sectors per track 20
Analysis Included in the RaceCapture App
Export data format Plain CSV (RaceRender compatible)
Physical
Dimensions 150 x 85 x 30mm (5.9 x 3.35 x 1.18in)
Temperature range -40 to 85c
Environmental IP50 rated
Weight 255g (12 oz)
Physical Molex Connector, 24 pins SMA for external GPS antenna SMA for cellular module
Power Consumption (max) Main System: 0.6W With Wireless: 1.6W With Cellular Telemetry: 8.6W With Cellular Telemetry and Wireless active: 9.6W
