RaceCapture-Pro MK4
Reference
Quick Start
Powering Up
Powering via 12v
  • Connect Red to 12v
  • Connect Black to Ground
Testing on the Bench
  • Note: When powering only with USB, the voltage reference output will only be at approximately 4.7 volts, which can cause a mis-reading of sensor values. When precise sensor readings are required, provide 12v power to RaceCapture.
Install the RaceCapture app
On Desktop
USB Drivers
  • Windows 10/11: Windows 10 has built in USB drivers that support RaceCapture; no separate driver installation needed.
  • Windows XP, 7, 8: Not supported due to outdated video drivers, but may work depending on the video hardware used. USB drivers will require installation instructions below.
On Raspberry Pi
Bluetooth (Android Only)
  • Note: Default bluetooth pin is 1234. You can change this later under Setup / Wireless in the app.
WiFi (iOS or Android)
  • Note: You can change the WiFi password later under Setup / Wireless in the app.
Launch the RaceCapture app
Next Steps
Using the RaceCapture app
Parameter Specification
Sensors – Analog Inputs
Channels 9 (8 external + 1 internal battery/supply voltage)
Voltage range 0–5V
Input impedance Greater than 1M ohm
Voltage protection 400V (intermittent)
ADC precision 12 bit
Maximum sample rate 1000Hz
Mapping Raw / linear formula / interpolated map
Digital I/O
Channels 4
Output mode type Open Drain
Input mode voltage range 0–12V
Input voltage protection 0–40V
Channels 4
Mapping RPM, Frequency
Voltage Reference
Output voltage / capacity 5V / 500mA
CAN Bus
CAN channels 2
CAN filters 14 per channel
Protocol support OBDII PID, custom CAN mapping
CAN bus standard CAN 2.0 compatible, 1M baud
Cellular Telemetry (Optional)
Cellular support 4G LTE worldwide compatible
Maximum sample rate 10Hz
WiFi 802.11bgn
WiFi modes Access Point, Infrastructure
Bluetooth Bluetooth 2.0 EDR
Maximum sample rate 50Hz (Bluetooth and WiFi)
GNSS
Constellations supported GPS, GLONASS, BeiDou, Galileo
Antenna type External active antenna
Sample rates supported 1 / 5 / 10 / 25Hz
Accuracy 2.0m CEP
Inertial Motion Unit
Accelerometer channels 3 (X/Y/Z) (2G, 4G capable)
Gyro channels 3 (Yaw/Pitch/Roll) (1000 degrees/sec)
Storage
Micro SD Up to 32GB (SDHC)
CAN bus direct mapping 100 direct CAN mapping channels
Capabilities
Channel support 200
Predictive lap timing Built-in
Track mapping Circuit and point-point
Track maps 200 built-in for autonomous auto-detection; unlimited via RaceCapture app with interactive track map builder
Sectors per track 20
Logging file format Plain CSV
Physical
Dimensions 150 × 100 × 30mm (5.9 × 3.35 × 1.18in); 5mm mounting ears on 140mm centers; enclosure body 85mm (connectors extend 15mm beyond enclosure)
Temperature range −40 to 85°C
Environmental rating Connectors IP67 / enclosure IP51
Weight 255g (12 oz)
Connectors M12 12P female (Analog inputs); M12 12P female (Digital/RPM inputs); M8 6P female (CAN1/CAN2/Power); M8 4P female (CAN1/Power); SMA (GPS); RP-SMA (Cellular)
Power supply & consumption (max) System voltage 9–24V (40V surge protection); Main system 0.6W; with Wireless 1.6W; with Cellular 8.6W; Cellular + Wireless active 9.6W
Recommended fuse 5A
