RaceCapture-Pro MK3
RaceCapture/Pro MK3 is motorsports telemetry system, packed with features for Endurance Racing, Sprint Racing, Autocross, Time Attack and more.
Product Brief
- Jump to quick start guide
- Hardware Installation guide
- Real-time Telemetry guide
- Logging Data
- CAN bus / ECU sensor guide
- OBDII Guide
- Lua scripting guide
- Lua script examples
- Sensor guide
- TPMS guide
- How to: get best GPS data
- How to update firmware
- How to build a RJ45 CAN Crossover Cable
- How to get up to 4 FreedomPop free 200MB/month Sim Cards for $0,01ea
- More FAQs and How-To's
- How To Videos
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Testing on the Bench
Launch the RaceCapture app
Bluetooth (Android Only)
WiFi (iOS or Android)
Once you've linked the Bluetooth or Wireless networks, launch the RaceCapture app.
Raspberry Pi
Connect to your RaceCapture system (On your laptop / desktop)
You can also run the RaceCapture app on your desktop or laptop to make it easier to set up, change settings and view analysis data.
Windows / OSX (USB only)
Windows Requirements
USB Drivers
- Windows 10: Windows 10 has built in USB drivers that support RaceCapture; no separate driver installation needed.
OSX
Connecting and running
RaceCapture App Tour
Setup Mode
Explanation of buttons
<img src="
" width="640"/>
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Selecting time vs distance
Android
iOS
| Parameter | Specification |
| Sensors – Analog Inputs | |
| Channels | 9 (8 external + 1 internal battery/supply voltage) |
| Voltage range | 0–5V |
| Input impedance | Greater than 1M ohm |
| Voltage protection | 400V (intermittent) |
| ADC precision | 12 bit |
| Mapping | Raw / linear formula / interpolated map |
| Digital I/O | |
| Channels | 3 |
| Output mode type | Open Drain |
| Input mode voltage range | 0–12V |
| Input voltage protection | 0–40V |
| Channels | 4 |
| Mapping | RPM, Frequency |
| Voltage Reference | |
| Output voltage / capacity | 5V / 500mA |
| CAN Bus | |
| CAN channels | 2 |
| Protocol support | OBDII PID, custom CAN mapping |
| CAN bus standard | CAN 2.0 compatible, 1M baud |
| Serial | |
| Auxiliary serial | RS232 |
| Maximum baud rate | 230400 |
| Cellular support | 3.5G GSM worldwide compatible |
| Maximum sample rate | 10Hz |
| Wireless | |
| WiFi | 802.11bgn |
| WiFi modes | Access Point, Infrastructure |
| Bluetooth | Bluetooth 2.0 |
| Maximum sample rate | 50Hz (Bluetooth and WiFi) |
| GPS | |
| GPS type | External active antenna |
| Sample rates supported | 1 / 5 / 10 / 25 / 50Hz |
| GPS accuracy | 2.5m CEP |
| Inertial Motion Unit | |
| Accelerometer channels | 3 (X/Y/Z) (2G, 4G capable) |
| Gyro channels | 3 (Yaw/Pitch/Roll) (1000 degrees/sec) |
| Storage | |
| CAN bus direct mapping | 30 direct CAN mapping channels |
| Capabilities | |
| Channel support | 200 |
| Predictive lap timing | Built-in |
| Track mapping | Circuit and point-point |
| Track maps | 200 built-in for autonomous auto-detection; unlimited via RaceCapture app with interactive track map builder |
| Sectors per track | 20 |
| Analysis | Included in the RaceCapture App |
| Export data format | Plain CSV (RaceRender compatible) |
| Physical | |
| Dimensions | 150 × 85 × 30mm (5.9 × 3.35 × 1.18in) |
| Temperature range | −40 to 85°C |
| Environmental rating | IP50 rated |
| Weight | 255g (12 oz) |
| Connectors | Molex connector; SMA for external GPS antenna; SMA for cellular module |
| Power consumption (max) | Main system: 0.6W; with Wireless: 1.6W; with Cellular Telemetry: 8.6W; Cellular + Wireless active: 9.6W |
