RaceCapture-Pro MK3
Revision as of 17:22, 25 October 2026 by Brentp (talk | contribs) (→Windows / OSX (USB only))
RaceCapture/Pro MK3 is motorsports telemetry system, packed with features for Endurance Racing, Sprint Racing, Autocross, Time Attack and more.
Product Brief
Download
By Car
By Sensor Type
Reference
More Information
Quick Start
Powering Up
Powering via 12v
Testing on the Bench
Launch the RaceCapture app
Bluetooth (Android Only)
WiFi (iOS or Android)
Once you've linked the Bluetooth or Wireless networks, launch the RaceCapture app.
Raspberry Pi
Connect to your RaceCapture system (On your laptop / desktop)
You can also run the RaceCapture app on your desktop or laptop to make it easier to set up, change settings and view analysis data.
Windows Requirements
USB Drivers
  • Windows 10: Windows 10 has built in USB drivers that support RaceCapture; no separate driver installation needed.
  • Windows XP, 7, 8: Not supported due to outdated video drivers, but may work depending on the video hardware used. USB drivers will require installation instructions below.
OSX
Connecting and running
RaceCapture App Tour
Navigating dashboard screens
Setup Mode
Explanation of buttons
Enabling Telemetry
Diagnostic Logs
Analysis Mode
Navigating data
Selecting time vs distance
Android
  • Under your Analysis session list, export your session by pressing the export button, to the right of the name of the session.
  • Export this to your local Android device storage.
  • Connect your Android device to your computer using a USB cable. The Android device will appear as a removable storage device.
  • Copy the exported log file from your Android device to your computer.
iOS
Parameter Specification
Sensors – Analog Inputs
Channels 9 (8 external + 1 internal battery/supply voltage)
Voltage range 0–5V
Input impedance Greater than 1M ohm
Voltage protection 400V (intermittent)
ADC precision 12 bit
Maximum sample rate 1000Hz
Mapping Raw / linear formula / interpolated map
Digital I/O
Channels 3
Output mode type Open Drain
Input mode voltage range 0–12V
Input voltage protection 0–40V
Channels 4
Mapping RPM, Frequency
Voltage Reference
Output voltage / capacity 5V / 500mA
CAN Bus
CAN channels 2
CAN filters 14 per channel
Protocol support OBDII PID, custom CAN mapping
CAN bus standard CAN 2.0 compatible, 1M baud
Serial
Auxiliary serial RS232
Maximum baud rate 230400
Cellular Telemetry (Optional)
Cellular support 3.5G GSM worldwide compatible
Maximum sample rate 10Hz
WiFi 802.11bgn
WiFi modes Access Point, Infrastructure
Bluetooth Bluetooth 2.0
Maximum sample rate 50Hz (Bluetooth and WiFi)
GPS type External active antenna
Sample rates supported 1 / 5 / 10 / 25 / 50Hz
GPS accuracy 2.5m CEP
Inertial Motion Unit
Accelerometer channels 3 (X/Y/Z) (2G, 4G capable)
Gyro channels 3 (Yaw/Pitch/Roll) (1000 degrees/sec)
Storage
Micro SD Up to 32GB (SDHC)
CAN bus direct mapping 30 direct CAN mapping channels
Capabilities
Channel support 200
Predictive lap timing Built-in
Track mapping Circuit and point-point
Track maps 200 built-in for autonomous auto-detection; unlimited via RaceCapture app with interactive track map builder
Sectors per track 20
Analysis Included in the RaceCapture App
Export data format Plain CSV (RaceRender compatible)
Physical
Dimensions 150 × 85 × 30mm (5.9 × 3.35 × 1.18in)
Temperature range −40 to 85°C
Environmental rating IP50 rated
Weight 255g (12 oz)
Connectors Molex connector; SMA for external GPS antenna; SMA for cellular module
Power consumption (max) Main system: 0.6W; with Wireless: 1.6W; with Cellular Telemetry: 8.6W; Cellular + Wireless active: 9.6W
