RaceCapture-Pro MK4
- Jump to quick start guide
- RaceCapture App user's guide
- Plug and play harness system for sensors and devices
- Jump to Hardware guide
- Real-time Telemetry guide
- Logging Data
- CAN bus / ECU sensor guide
- OBDII Guide
- Sensor guide
- Lua scripting guide
- Lua script examples
- TPMS guide
- How to: get best GPS data
- How to update firmware
- More FAQs and How-To's
- How To Videos
Reference
Quick Start
Powering Up
Powering via 12v
- Connect Red to 12v
- Connect Black to Ground
Testing on the Bench
- Note: When powering only with USB, the voltage reference output will only be at approximately 4.7 volts, which can cause a mis-reading of sensor values. When precise sensor readings are required, provide 12v power to RaceCapture.
Install the RaceCapture app
On Desktop
USB Drivers
On Raspberry Pi
Bluetooth (Android Only)
- Note: Default bluetooth pin is 1234. You can change this later under Setup / Wireless in the app.
WiFi (iOS or Android)
- Note: You can change the WiFi password later under Setup / Wireless in the app.
Launch the RaceCapture app
Next Steps
Using the RaceCapture app
| Sensors | ||
| Analog Inputs | ||
| Channels | 9 (8 external + 1 internal battery/supply voltage) | |
| Voltage range | 0-5v | |
| Input impedance | Greater than 1M ohm | |
| Voltage Protection | 400v (intermittent) | |
| ADC precision | 12 bit | |
| Maximum sample rate | 1000Hz | |
| Mapping | Raw / linear formula / interpolated map | |
| Digital I/O | ||
| Channels | 4 | |
| Output mode type | Open Drain | |
| Output current capacity | 1A, inductively clamped | |
| Input mode voltage range | 0-12v | |
| Input voltage protection | 0-40v | |
| Timer inputs (RPM / Frequency) | ||
| Channels | 4 | |
| Mapping | RPM, Frequency | |
| Voltage Reference | ||
| Output Voltage / Capacity | 5v / 500mA | |
| CAN Bus | ||
| CAN Channels | 2 | |
| CAN baud rate | 125K, 250K, 500K, 1M Baud | |
| CAN filters | 14 per channel | |
| Protocol Support | OBDII PID, custom CAN mapping | |
| CAN Bus | CAN 2.0 compatible, 1M baud | |
| CAN termination | Software controlled | |
| Serial | ||
| Aux Serial | RS232 | |
| Max Baud Rate | 230400 | |
| Cellular Telemetry (Optional) | ||
| Optional Cellular | 4G LTE worldwide compatible | |
| Maximum Sample Rate | 10Hz | |
| Wireless | ||
| WiFi | 802.11bgn | |
| WiFi Modes | Access Point, Infrastructure | |
| Bluetooth | Bluetooth 2.0 EDR | |
| Maximum Sample Rate | 50Hz (Bluetooth and WiFi) | |
| GNSS | ||
| Constellations Supported | GPS, GLONASS, BeiDou, Galileo | |
| Antenna Type | External active antenna | |
| Sample Rates supported | 1 / 5 / 10 / 25Hz | |
| Accuracy | 2.5M CEP | |
| Inertial Motion Unit | ||
| Accelerometer Channels | 3 (X/Y/Z) (2G, 4G capable) | |
| Gyro Channels | 3 (Yaw/Pitch/Roll) (1000 degrees/sec) | |
| Storage | ||
| Micro SD | Up to 32GB (SDHC) | |
| CAN bus direct mapping | 100 direct CAN mapping channels | |
| Capabilities | ||
| Channel Support | 200 | |
| Predictive Lap Timing | Built-in | |
| Track Mapping | Circut and point-point | |
| Track maps | 200 built in for autonomous auto-detection; unlimited via RaceCapture app with interactive track map builder | |
| Sectors per track | 20 | |
| Logging file format | Plain CSV | |
| Physical | ||
| Dimensions | 150 x 85 x 30mm (5.9 x 3.35 x 1.18in) | |
| Temperature range | -40 to 85c | |
| Environmental | Connectors: IP67 / enclosure IP51 | |
| Weight | 255g (12 oz) | |
| Connectors | M12 12P female (Analog inputs); M12 12P female (Digital / RPM inputs); M8 6P female (CAN1/CAN2/Power); M8 4P female (CAN1/Power); SMA (GPS); RP-SMA (Cellular) | |
| Power supply and Consumption (max) | Power supply voltage: 9 - 24v (40v surge protection) | Main System: 0.6W With Wireless: 1.6W With Cellular Telemetry: 8.6W With Cellular Telemetry and Wireless active: 9.6W |
