RaceCapture-Pro MK4
- Jump to quick start guide
- RaceCapture App user's guide
- Plug and play harness system for sensors and devices
- Vehicle Specific Guides
- Jump to Hardware guide
- Real-time Telemetry guide
- Logging Data
- CAN bus / ECU sensor guide
- OBDII Guide
- Sensor guide
- Lua scripting guide
- Lua script examples
- TPMS guide
- How to: get best GPS data
- How to update firmware
- More FAQs and How-To's
- How To Videos
Reference
Quick Start
Powering Up
Powering via 12v
- Connect Red to 12v
- Connect Black to Ground
Testing on the Bench
- Note: When powering only with USB, the voltage reference output will only be at approximately 4.7 volts, which can cause a mis-reading of sensor values. When precise sensor readings are required, provide 12v power to RaceCapture.
Install the RaceCapture app
On Desktop
USB Drivers
On Raspberry Pi
Bluetooth (Android Only)
- Note: Default bluetooth pin is 1234. You can change this later under Setup / Wireless in the app.
WiFi (iOS or Android)
- Note: You can change the WiFi password later under Setup / Wireless in the app.
Launch the RaceCapture app
Next Steps
Using the RaceCapture app
Sensors | |
Analog Inputs | |
Channels | 9 (8 external + 1 internal battery/supply voltage) |
Voltage range | 0-5v |
Input impedance | Greater than 1M ohm |
Voltage Protection | 400v (intermittent) |
ADC precision | 12 bit |
Maximum sample rate | 1000Hz |
Mapping | Raw / linear formula / interpolated map |
Digital I/O | |
Channels | 4 |
Output mode type | Open Drain |
Input voltage protection | 0-40v |
Timer inputs (RPM / Frequency) | |
Channels | 4 |
Mapping | RPM, Frequency |
Voltage Reference | |
Output Voltage / Capacity | 5v / 500mA |
CAN Bus | |
CAN Channels | 2 |
Optional Cellular | 4G LTE worldwide compatible |
Maximum Sample Rate | 10Hz |
Wireless | |
WiFi | 802.11bgn |
Bluetooth | Bluetooth 2.0 EDR |
Maximum Sample Rate | 50Hz (Bluetooth and WiFi) |
GNSS | |
Constellations Supported | GPS, GLONASS, BeiDou, Galileo |
Antenna Type | External active antenna |
Sample Rates supported | 1 / 5 / 10 / 25Hz |
Accuracy | 2.5M CEP |
Inertial Motion Unit | |
Accelerometer Channels | 3 (X/Y/Z) (2G, 4G capable) |
Gyro Channels | 3 (Yaw/Pitch/Roll) (1000 degrees/sec) |
Storage | |
CAN bus direct mapping | 100 direct CAN mapping channels |
Capabilities | |
Channel Support | 200 |
Track maps | 200 built in for autonomous auto-detection; unlimited via RaceCapture app with interactive track map builder |
Sectors per track | 20 |
Logging file format | Plain CSV |
Physical | |
Dimensions | 150 x 100 x 30mm (5.9 x 3.35 x 1.18in) enclosure; 5mm mounting ears on 140mm centers; Enclosure body 85mm (connectors extend 15mm beyond main enclosure body). |
Environmental | Connectors: IP67 / enclosure IP51 |
Weight | 255g (12 oz) |
Connectors | M12 12P female (Analog inputs); M12 12P female (Digital / RPM inputs); M8 6P female (CAN1/CAN2/Power); M8 4P female (CAN1/Power); SMA (GPS); RP-SMA (Cellular) |
Power supply and Consumption (max) | System voltage: 9 - 24v (40v surge protection) / Power: Main System: 0.6W With Wireless: 1.6W With Cellular Telemetry: 8.6W With Cellular Telemetry and Wireless active: 9.6W |
Recommended Fuse | 5A |
